To revert an upgrade, the Rolling Upgrade process is performed in reverse order by
completing the following steps:
Determine which partition is
currently selected on each node by entering the show slot
detail command.
The
include keyword can be used to simplify the output. In
the following example, the Backup and both Standy nodes have been rebooted and
are running the newer software
version:
# show slot detail | include "information|Image|State|ver:"
Slot-1 information:
State: Operational
Current State: MASTER
Image Selected: primary
Image Booted: secondary
Primary ver: 31.3.1.22
Secondary ver: 31.3.0.106
Slot-2 information:
State: Operational
Current State: BACKUP (In Sync)
Image Booted: primary
Slot-3 information:
State: Operational
Current State: STANDBY
Slot-4 information:
State: Operational
Change the selected software partition to the old version on all nodes by
entering the use image secondary command.
When all nodes have the old
software version selected, reboot each node running the new software version,
starting with the Backup node first.
When the Backup node reboots,
it should go back to “In-Sync” with the Primary node.
After each reboot,
allow a few minutes for the network to converge before
proceeding.
Reboot any Standby nodes individually, ensuring that the rebooted node is
operational before moving on to the next node.
When all nodes are running the old software version, the
upgrade is reverted. At this point, all nodes should have both their selected and booted
partitions set to the partition that contains the old software version.
